Digital Circuit - 8 bits in, selectable out
seanwright
Joined Feb 24, 2011
Hello Everyone,
I was wondering if anyone could give me some ideas on the following:
I have a digital inputs (bits) which will be used to control different devices and so I would like to be able to select the device using some sort of digital switch (?). Is there a digital IC that can take 8 inputs and then re-route to different outputs based on selector pins?
Thanks in advance!
Sean
GetDeviceInfo
Joined Jun 7, 2009
2,196
a small ROM makes a good decoder. Your address (inputs) would determine your ouputs (data). Newer flash memories make it easy to reprogram as required.
