digital building blocks
Discussion in 'General Electronics Chat' started by relicmarks, Nov 17, 2008.
  1. relicmarks
    Thread Starter Active Member
    Oct 13, 2006
    355
    I have a problem of knowing the basic digital building blocks
    With Analog building blocks i don't have a problem because when looking at a schematic of analog symbols and circuits/networks i can tell thats a summing mixer, differentiator, intergator, small single amplifier, pre-amp, poweramp, etc.
    But with digital building blocks its more complex to know what the blocks are really cause its mixed up with all kinds of different gates,invertors,buffers,adders,subtractors,counters,flip flops etc.
    Is there any turtorials or pictures of digital building blocks , so when i look at a schematic that has digital circuits i can BREAK up the schematic into BLOCKS
    This is the adder stage, this is the subtractor stage, 4 bit count down counter circuit/stage, 4 bit synchronous Counter circuit/stage
    ,Asynchronous Decade Decimal 10 counter circuit/stage,3 bit up and down counter circuit/stage
    Back in your 70's or 80's digital electronic classes or jobs , what stages/sections or blocks do u guys know of ?
    I don't have a cookbook of digital building blocks but i'm trying to make one for myself
    Just very simple building blocks for digital electronics
  2. mik3
    Feb 4, 2008
    4,846
    63
  3. relicmarks
    Oct 13, 2006
    355
    do you know any others like that?
    or any other turtorials for digital electronics ?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Back in the 60's, the basic building block was the NOR gate. A bit later, it was the NAND gate. You can make any logic function with either of those gates.
    To be more practical, you should be able to get a data sheet for any logic IC with a diagram of the basic functions drawn out.
  5. mik3
    Feb 4, 2008
    4,846
    63
    I bet a simple search in google will reveal thousands of them.
  6. relicmarks
    Oct 13, 2006
    355
    oh yes i have done that
    its kinda of hard what im trying to say
    Since im not the designer of the digital circuits/networks or do R&D work at my job
    I don't know how these digital circuits or networks are suppost to work or do
    so i have just printed out digital building blocks from turtorials and tried to COMPARE them with the schematics to see it i can find any stages/sections/blocks that look similar or alike
    Trying to break down digital circuits into Blocks is hard for me because the result or outputs of these are not the same as the ones in turtorials or electronic books
    Truth tables tell up the inputs and outputs
    But a digital circuit is many truth tables combined,mixed,splitted,arranged,added,subtracted
    So i don't know how the logic signals are composed
    Truth tables don't tell a tech. the "Intermediates signals" that are inbetween the inputs and outputs
    the basic building block was the NOR gate and NAND gate
    If you make a adder circuit out of NOR and NAND gates or a COUNTER out of NOR or NAND Gates manually
    The truth tables will just tell you the inputs and outputs for individual NOR or NAND
    The "intermediates signals" are all the 1's and 0's inbetween the inputs and outputs circuits that are either inverted,buffed,added,subtracted,flip,flop,etc.
  7. Manvir
    Jul 17, 2013
  8. crutschow
    Mar 14, 2008
    13,469
    3,356
    It can be difficult to know what a block of logic circuits are doing if it's not apparent what the circuit is meant to do. You generally need an idea of the purpose of the circuit and the input and output signals to determine its function.
  9. GopherT
    Nov 23, 2012
    6,297
    4,019
  10. ErnieM
    Apr 24, 2011
    7,434
    1,625
    You folks do realize that relicmarks (the OP here) has not made a post in the last 4 years?
    Plus no one mentioned the classic book on logic building blocks:
    GopherT likes this.
  11. crutschow
    Mar 14, 2008
    13,469
    3,356
    Curses. Suckered again by the New Member who resurrects ancient posts. :p
    ErnieM likes this.
