1. variable integer divided by another variable integer.You need to be more specific in what you want.
Do you want to divide an variable integer by a fixed integer or do you want to divide one variable integer by another variable integer?
Do you want an integer result, or a fixed point result, or a floating point result?
What is the width of the dividend and the divisor?
Do you need this to be purely combinational, or can it be sequential?
How are you planning on implementing it? Discrete gates, programmable logic, what?
Use a microcontroller. Unless this is a school assignment which it probably is.1. variable integer divided by another variable integer.
2.floating point result required.
3.dividend 5bit,divisor3 bit.
4.purely combinational logic
5.implementation : programmable logic
So what is the floating point representation you need?1. variable integer divided by another variable integer.
by Jake Hertz
by Aaron Carman
