digipots push button control
Discussion in 'Electronics Resources' started by prinsloo.n.m, Dec 27, 2011.
  1. prinsloo.n.m
    Dec 27, 2011
    I am lookingg for a digital potentiometer with a external 10 v source that will be the master feeding 4 slave digipots that can also be individualy controled via up/down push buttons
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    Can you please elaborate in a bit more detail? It is not clear what you are trying to do.
  3. prinsloo.n.m
    Dec 27, 2011
    with a 10vdc sypply i want to control it from 0 - 10 vdc as a master digipot that feeds 4 individual digipots that control 4 sepatate vsd motor drives.
    Setting the master to eg, 5 volts none of the slaves can go higher than 5 volts> once syncro speed on all 4 drives are set up the master then control speed of all 4 drives
  4. MrChips
    Oct 2, 2009
    12,623
    3,451
    How much current does one motor require?
    What is the operating voltage range of each motor?
    What is the model number of the motor?
    No digipot will have the current capability to drive your motor.
  5. BillB3857
    Feb 28, 2009
    2,402
    348
    Have you put "digipot" into Google? Data sheets with application examples are there.
