differnece between inverting and non-inverting
Discussion in 'General Electronics Chat' started by nepdeep, Nov 7, 2012.
  1. nepdeep
    Sep 14, 2011
    139
    A lot of times...I have heard people saying not a lot of difference between inverting and non-inverting except for thing like bandwidth of non-inverting is more than the inverting amplifier....i see the major difference...-ve and the +ve output...or does it not matter ....for example...if we use inverting adder...the output is -ve..or if we use inverting buffer output is -ve...what is the use of having inverting buffer...??
    could you please clarify??
  2. Brownout
    Jan 10, 2012
    2,375
    998
    There are LOTS of uses for inverting buffers. How much time do you have? Ok, let's say you want an LED to illuminate using a low-side switch when an input signal goes to zero. So, you connect the input of the switch to an inverting buffer, and when the input is zero, the switch is activated. You can make up more examples on your own. Also, input impedance, output impedance, bandwidth, offset, etc. are influenced by the amp topology.
  3. nepdeep
    Sep 14, 2011
    139
    I meant buffer not inverter....as far as i think you suggested me about the inverter...0-1 or 1-0 but in I meant about the opamps...like 2 to -2 or 3 to -3...etc...where do we use the inverted output like -3...in practical...
  4. ScottWang
    Aug 23, 2012
    4,933
    777
  5. crutschow
    Mar 14, 2008
    13,505
    3,376
    A major reason for the inverting configuration is that it makes a summing amplifier that has no interaction between the various inputs. Also it works well as a near ideal integrator.
    The non-inverting amplifier has interaction between inputs if you try to use it as a summing amp and it does not make an ideal integrator.
  6. atferrari
    Jan 6, 2004
    2,668
    784
    Hola crutschow.
    I think I understand the first but could you please elaborate on the second?
    Gracias.
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The basic difference is that a non-inverting amplifier has 0° phase change
    and a inverting amplifier has a 180° phase change.
    Bertus
  8. ramancini8
    Member
    Jul 18, 2012
    447
    119
    Inverting stage yields pure integration; non-inverting yields a low frequency pole.
    nepdeep likes this.
  9. crutschow
    Mar 14, 2008
    13,505
    3,376
    In a non-inverting amp, the summing is done at the positive input, which is not a virtual ground point, it varies with any input voltage. Thus any signal voltage at that point will be seen by all inputs connecting to that point if there is more than one input. Thus the interaction between inputs.
    keithostertag and nepdeep like this.
  10. atferrari
    Jan 6, 2004
    2,668
    784
    So simple...and I had to ask. Sorry.
    Thanks.
  11. timescope
    Member
    Dec 14, 2011
    298
    44
    Here is a link to a brief comparison of noise, distortion and the effects of the common mode rejection ratio (CMRR) for the inverting and non-inverting configurations.
    Technote 3
    Timescope
