differential operator identity
Discussion in 'Math' started by Starhowl, Dec 7, 2013.
  1. Starhowl
    Dec 3, 2013
    25
    Can someone please explain to me why this identity is valid? Especially how the author gets to this:
    \nabla_q \times \frac{M_c}{|r_{qa}|} = -M \times \nabla_q \frac{1}{|r_{qa}|}.
    I assume that c stands for 'constant'..?
  2. WBahn
    Mar 31, 2012
    18,079
    4,917
    How can it possibly be valid if there is an Mc on one side and an M on the other?
    Unless you have an already-defined relationship between the two.
    Are you sure we have all the information?
  3. studiot
    Nov 9, 2007
    5,005
    515
    Is this about magnetization?
    If so you need to specify the units of M since engineers and physicists use different units and this affects formulae.
    Is your author calculating total magnetization from induced plus permanent, hence the M_sub_c, or is the M_sub_c unit M in a particular direction and M the total over a whole shell ?
    As WBahn says we need more information.
  4. Starhowl
    Dec 3, 2013
    25
    I'm sure I provided all the information; as far as I do understand this is a general valid relation where the vector could be also of the name 'u' or 'v'. Furthermore, as far as I can see, the index 'c' indicates 'constant', or, respectively 'held constant'.
  5. studiot
    Nov 9, 2007
    5,005
    515
    I'm sure you will find better responses if you cooperate with others.
    WBahn, in particular is a very skilled teacher in these subjects, so if he asks for more detail, you can be quite sure yours is sparse.
    So put your question in context and tell us what you are studying,
    What is the book ( a page reference could be helpful since others may know it),
    What area of your subject is the book developing, it certainly doesn't quote formulae in complete isolation.
  6. WBahn
    Mar 31, 2012
    18,079
    4,917
    But think about this. If M could be u and Mc could be v, than can't I change u one one side without changing v on the other? That means that the each side must fundamentally be equal to the same constant value independent of the values of M or Mc. Does that make sense?
  7. Starhowl
    Dec 3, 2013
    25
    No, I never meant to be M like u and Mc like v.
  8. WBahn
    Mar 31, 2012
    18,079
    4,917
    Well, then what did you mean?
    The same argument still applies. If there is no fixed relationship between M and Mc, the what prevents one from changing and the other from staying the same? If that happens, how can the two sides remain equal?
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    The OP deleted a post, the reason given was "problem solved". It would have been nice if he had said it out loud.
