Differential input differential output ,butterworth LC Low pass active
arunkuttath
Joined Oct 5, 2015
i want to implement a filter , butterworth filter with LC active circuitry.
Please tell me how to implement it . i also want to input and outputs signals in differential mode. So the chance is an active filter
Thanks in advance
Arun
Papabravo
Joined Feb 24, 2006
21,228
Active filters do not generally use inductors. You need to do some basic research before we can move forward. Please acquaint yourself with the circuit known as a Sallen-Key filter. Cascading 1st and 2nd order sections is how filters of higher order are constructed.
arunkuttath
Joined Oct 5, 2015
thank you all
i want a general solution for the butterworth or sallen-key etc. But the circuit must be a LC circuit.
I just want what are the things that i want to consider ? please post some pdf or other design guidelines that can satisfy my requirement.
regards
Arun
Papabravo
Joined Feb 24, 2006
21,228
We don't know what your requirements are. You mentioned "LC active circuitry", but I suspect you have no idea what that implies.
In order to design ANY kind of filter you need to decide:
  1. Where is the passband
  2. How much ripple is allowed in the passband
  3. Where is the stopband
  4. How much ripple is allowed in the stopband
  5. What rolloff is required in the transition band
From this information we can determine the required order of the filter and then we can talk about weather it consists of passive components, L's and C's, or active components like opamps, R's and C's.
You might find the following references helpful
http://www.crbond.com/papers/btf2.pdf
https://sarviechousite.files.wordpress.com/2014/04/analogue_filter_design.pdf
Papabravo
Joined Feb 24, 2006
21,228
thank you all,
but there is nothing with the differential filters.
In point of fact, in a career spanning half a century, I've never seen anything on this subject either. I suppose one could design a standard filter with differential to single-ended conversion on the input and single-ended to differential conversion on the output.
BTW - Differential signals are normally used for data transmission. The fast edges are rich in harmonics and a filter would only distort the waveform with possibly unintended and disastrous consequences. I'm thinking that filtering ANY differential signal makes no sense at all. The constant refrain is "Don't let the eye close". Maybe you are working with something we mere mortals cannot comprehend and so a bit of background might be helpful.
alfacliff
Joined Dec 13, 2013
2,458
the term is ballanced, in rf filters there are unballanced, one side grounded, and ballanced filters. look up ballanced filter design.
