Differential equations
Discussion in 'Homework Help' started by MrRockchip, May 25, 2010.
  1. MrRockchip
    May 25, 2010
    18
    Please, tell me, what are the Correct differential equations
    for calculating the electric current on inductivity ? :confused:
    http://myimgs.net/images/zynyf.jpg
    I've created some equations, but at the end (after solving them)
    I get the wrong result - so, they were wrong. :(
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Voltage, Vr, across a resistor R, according to Ohm's Law, is "I*R"
    Voltage, Vl across an inductor L is L*(di/dt)
    The result of writing KVL around a loop should be a first order equation. with a step function representing the closing or opening of the switch. Does that help?
    MrRockchip likes this.
  3. MrRockchip
    May 25, 2010
    18
    For inductor:
    i(-0)=E/R;
    L(di/dt)=E / ((R*R)/R+R);
    L(di/dt)=2*E/R;
    (di/dt) = 2*E/(R*L)
    Because E,R,L=const., after integrating :
    i(t)=(2*E/(R*L))*t
    Something is wrong here, because i(t) can't be infinite;
    it's obvious that i(+inf)=E/R . :(
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    Here's a start ... note that R2 only determines the value of I_{0}
    L\frac{di}{dt}+R_{1}i=E
    \frac{di}{(\frac{E}{R_{1}}-i)}=\frac{R_{1}}{L}dt
    \int^{i}_{I_{0}}\frac{di}{(\frac{E}{R_{1}}-i)}=\int^{t}_{0}\frac{R_{1}}{L}dt
  5. MrRockchip
    May 25, 2010
    18
    Thank you, Tnk! :)
    Here's my solution:
    We know that [​IMG]
    So, the final answer is [​IMG]
    It seems to be correct, because
    Am i right ? ;)
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Actually
    I_{0}=\frac{E}{R_{1}||R_{2}}
    You happened to have
    I_{0}=\frac{2E}{R_{1}}
    "correct" only because R1=R2 in the problem statement.
    Otherwise you appear to have got a handle on the problem solution.
