Well, it sounds like you don't want to setup the equation yourself. Whoever gave you the circuit has the equation, ask them.Well, technically I have got to model an ignition circuit using Pspice and get simulation results that match experimental data.
This part is dealt with, but now I would like to get the differential equations (that Pspice solved) that govern the system in order to use them in another software.
If I can get them using Pspice it would be much easier than if I had to find them "manually".
Ok, that sort of makes sense.I made the circuit myself by looking at some information available in the literature and then tuned it myself to make the results match the experimental data.
There was however no equation provided with the schematics of the circuit that i used.
Take a look at Example 5.1 on Page 210: http://books.google.com/books?id=II...e&q=differential equation of ignition&f=falseAs it is quite a complicated circuit ( at least for me ) I would say so yes. And moreover, i want to make sure that the differential equations that I will later use are the ones that Pspice solved to trace the response I asked it to give me.
Thread starter | Similar threads | Forum | Replies | Date |
A | Buck converter modelling simulation - differential equations | PCB Layout , EDA & Simulations | 17 | |
Ordinary Differential Equations | Homework Help | 5 | ||
S | RL differential equations | Homework Help | 13 | |
Differential Equations | Homework Help | 9 | ||
D | Stuck on homework question involving differential equations of RC circuit | Homework Help | 3 |
