differential amplifier
Discussion in 'Homework Help' started by bug13, May 7, 2013.
  1. bug13
    Feb 13, 2012
    1,214
    38
    I am not sure about the following question, as the values look a bit odd.
    Q:
    Draw the circuit of a differential amplifier with a gain of 2 that has an input resistance of 10K, show pin details
    here is my drawing:
  2. Ron H
    Apr 14, 2005
    7,050
    657
    The V_in_2 input resistance is 10k. What about V_in_1?
  3. bug13
    Feb 13, 2012
    1,214
    38
    I am assuming they are looking for something R1 = R2, R3 = R4, as the question only asks for input resistance, not asks for R_Vin_1 and R_Vin_2.
    Did I answer what you are expected?
  4. Ron H
    Apr 14, 2005
    7,050
    657
    If V_in_1 and V_in_2 are two independent sources, then the input resistances in your schematic are NOT equal.
    If you have a single voltage source connected across the inputs, the input resistance is STILL not 10k.
  5. bug13
    Feb 13, 2012
    1,214
    38
    I am lost, can you tell me a bit more?
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    So - do you require the resistance as "seen" by an input signal source connected between the differential input terminals to be 10kΩ?
  7. bug13
    Feb 13, 2012
    1,214
    38
    The question in the OP is word by word from our exercise, I am not sure, but from what I understand it, is the resistance to the ground.
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    What do you mean by "resistance to ground". You suggest this is your understanding of the wording. How do you know this is what was meant by the wording?
  9. bug13
    Feb 13, 2012
    1,214
    38
    I mean the resistance see by the inputs, not the resistance between the inputs, but I don't think I truly understand the question, I will need some help.
  10. t_n_k
    Mar 6, 2009
    5,448
    783
    OK - so let's say we connect V_in_2 directly to ground and connect a non-zero ground referenced input to V_in_1. What is the input resistance on each input?
  11. Ron H
    Apr 14, 2005
    7,050
    657
    This is the circuit (attached) I would draw in response to that question.
    With two voltage sources, there are two input resistances.
  12. bug13
    Feb 13, 2012
    1,214
    38
    I got R2+R1||R4, is that what you expected?
    but isn't it become an inverting amplifier?
  13. bug13
    Feb 13, 2012
    1,214
    38
    We have talk about input impedance (of differential amplifier) in class, I am guessing the tutor want us to look the info up.
    but good to know there are two input resistances with two voltage source.
    so do you consider a high side current sensing circuit as one voltage source?
  14. bug13
    Feb 13, 2012
    1,214
    38
    Arrrh, are you trying to guild me to R_in_1 = R2+R1||R4, and R_in_2 = 0?
  15. t_n_k
    Mar 6, 2009
    5,448
    783
    Since the context is differential amplifier I would tend to make a distinction (if any) between differential mode and common mode input resistance.
  16. Ron H
    Apr 14, 2005
    7,050
    657
    This is homework. What do you think, and why?
  17. bug13
    Feb 13, 2012
    1,214
    38
    more to google: differential mode and common mode input resistance
  18. bug13
    Feb 13, 2012
    1,214
    38
    Ooops, I suppose to type "we HAVE NOT talked about this in class"
    and I think yes, a high side current sense is usually powered from the same source .
