Differential Amplifier
Discussion in 'General Electronics Chat' started by dhpatil, Jun 18, 2007.
  1. dhpatil
    Jun 18, 2007
    5
    Hi All,
    I am using a differential amplifier. I had one doubt regarding input to the differential amplifier. Is it required to connect the circuit ground to the differential input common terminals? If i did so i am getting well stable data, and not then got so many fluctuations for output. So can any body guide me in this matter.
    Dhairyashil
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    It would be helpful if you provided a schematic of your differential amplifier.
    There are applications for differential amplifiers where the input signal source needs no ground. One such application is a magnetic read-head.
    hgmjr
  3. dhpatil
    Jun 18, 2007
    5
    Hi
    I am attaching the schematic for differential amplifier. The three stage classical Instrumentation amplifier is used in differential mode. Can you give me suggestions in this circuit. The amplifier works on +12V and -5V supply. Vinst_out is the output to be monitored.
    Dhairyashil
  4. mozikluv
    Jan 22, 2004
    1,437
    where's the attachment? or are you having trouble uploading your schem?
    moz
  5. dhpatil
    Jun 18, 2007
    5
    Attached the file. Can u see it?
  6. mozikluv
    Jan 22, 2004
    1,437
    in what format have u place your schem? or have u used the "manage attachment" button to upload your file?
    moz
  7. dhpatil
    Jun 18, 2007
    5
    Hi
    I had used manage attachment at first and the file has format bmp.
  8. dhpatil
    Jun 18, 2007
    5
    Hi
    Can any body explain me how should i use instrumentation amplifier in Differential mode with input signal source ground isolated from circuit ground?
  9. Distort10n
    Dec 25, 2006
    429
    You could use an isolation amplifier which isolates the two grounds. This will give you protection, and supply you with an input bias return path to ground for the instrumentation amplifer.
    What is your design?
  10. mozikluv
    Jan 22, 2004
    1,437
    have you noticed that your bmp format must not exceed 2mb? if your file size is more than that, it's a no can do situation
    moz
