Differential Amplifier
Discussion in 'Homework Help' started by hncelectronics123, Jun 4, 2008.
  1. hncelectronics123
    May 23, 2008
    10
    Hello Guys
    Any help on the folowing question would be much appreciated.
    I have a wheatstone bridge with an output of 23.3mV and require a differential amplifier with a voltage gain of 30v to achieve an output of 4v.
    I have been using multi-sim 9 to simulate this operation but keep on having no luck. I'm aware that the surrondung resistor values should be of a calculated value but this is where i'm stuck.
    This may be of help
    12.50v from the resistors without the strain guage.
    The part where my strain guage is i get an output of 12.477v
    As you can see the voltage voltage difference is 23mV
    Thanks in advane:)
  2. mik3
    Feb 4, 2008
    4,846
    63
    Can you post your schematic as we can see which circuit to you use?
  3. hncelectronics123
    May 23, 2008
    10
    Hey yeah sure.
    Ignore the wheatstone bridge, on the (- input) of the amplifier i have 12.477v. and on the (+ input) of the amplifer i have 12.50v.
    Also do i need the 2 x resistors inbetween the amplifier and the bridge circuit? Thanks
  4. mik3
    Feb 4, 2008
    4,846
    63
    http://www.allaboutcircuits.com/vol_3/chpt_8/9.html
    Use this circuit as your differential amplifier and then connect the wheatstone bridge. I suggest you use the second circuit because it wont affect the operation of the wheatstone as much as the first circuit but the first circuit will be good if you use high values for the resistors on the op-amp.
    The formula for the gain is :
    Vout/Vin=Gain=V2*((1+R2/R1)/(1+R3/R4))-V1*R2/R1
    where R1 is the top left resistor
    R2 is the top right
    R3 is the bottom left
    R4 is the bottom right
  5. hncelectronics123
    May 23, 2008
    10
    Hey thanks for the help.
    Clarified the voltages on Multi sim and all checked out well. Cheers
