Differential Amplifier with Capacitor
Discussion in 'General Electronics Chat' started by guitarpsycho182, Aug 29, 2011.
  1. guitarpsycho182
    Jun 20, 2011
    Can anyone help me with this problem? I'm trying to convert this circuit to the s-domain for further analysis but the capacitor is stumping me. It's a basic differential amplifier circuit, but there is a capacitor tied between the two op-amp inputs. I'm trying to figure out what the effect would be as the cap value changes.
    http://upload.wikimedia.org/wikiped...g/300px-Op-Amp_Differential_Amplifier.svg.png
    R1 = Rf
    R2 = Rg
    Thanks!
  2. CraigHB
    Member
    Aug 12, 2011
    127
    15
    When I run into this kind of thing, I usually go straight to SPICE. So much easier than doing analysis by hand and you can see things graphically with a mouse click. Unless, of course, you need to do it as a learning exercise.
    I was recently working out a differential amplifier for a current sensing circuit myself. I just tried different values of capacitance in the simulator until I got the bandwidth where I needed it.
    If you don't have ready access to a SPICE program, LTSPICE is free. I like it a lot and it does what I need to do.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    My guess is that if the op-amp is ideal a cap across the +/- input terminals would have no effect.
  4. CraigHB
    Member
    Aug 12, 2011
    127
    15
    For an ideal op-amp with no feedback, yes, a cap across the inputs would have minimal effect. However, putting a cap accross the inputs on a differential amp with reasonable gain acts as a low-pass filter. Useful if you need to filter out noise from something like a DC-DC converter.
  5. t_n_k
    Mar 6, 2009
    5,448
    783
    So if the OP wants to derive a mathematical s-domain representation then they would need to substitute the ideal op amp with a non-ideal op-amp model. As a start they could assume a finite gain with infinite bandwidth.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Making the assumption about non-infinite gain (|Av|) but ideal op-amp properties in all other respects, I have the s-domain output voltage in terms of the differential inputs V1 and V2 as ...
    V_o=-\frac{\frac{V_1 R_f}{R_1+R_f}-\frac{V_2R_g}{R_2+R_g}}{\frac{1}{A_v}+\frac{R_1}{R_1+R_f}\{ 1+\frac{R_fCs}{A_v} \}}
    Needs checking but superficially looks OK.
    One would imagine adding additional non-ideal properties would increase the analytical burden significantly. This is why CraigHB's suggestion of using simulation makes a lot of sense.
    If all R's were the same value R & (2/Av)<<1 then the simplified result is ...
    V_o=-\frac{V_1-V_2}{1+\frac{RCs}{A_v}}
