Differential Amplifier design
Discussion in 'Homework Help' started by Rumination, Mar 25, 2016.
  1. Rumination
    Mar 25, 2016
    74
    The figure shows a differential amplifier with a differential input vid = (vin_d_pos - vin_d_neg) between the bases of Q1 and Q2, and an output (out) at the emitter of Q4.
    I have to Determine R1, R2, R4, R5 and R6 so that the following requirements are met:
    R 1 = R 2
    Av = vout / vid = 100 [V / V]
    Vout = 0V when Vin_d_pos = Vin_d_neg = 0V.
    The output Vout must be able to deliver undistorted peak signal voltage in the range
    from vout-min to vout-max with RL armed.
    Quiescent current IC = 10 * Q3-Q4 IB
    I have been given the values:
    Vcc-pos = 21 V
    Vcc-neg = 21 V
    R3 = 2000 Ohm
    RL = 49 Ohm
    I1 = 3,56 mA
    Vout-max = 8,8 V
    Vout-min = -8,8 V
    How can I start? For I have difficulty getting started.
  2. Rumination
    Mar 25, 2016
    74
    My English is not so good. I have found this out:
    Vcm = 0 , Vin_D = 0
    VB1 = VB2 = 0 V.
    Ic1 = IE1 = I/2 = 3,65 / 2 = 1,825 mA
    VB3 = 8,8 V - R3 * Ic1 = 8,8 V - 2000 * 1,825 mA = 5,15 V.
    Ic3 = IE3 = (24 V - VB3 - 0,7 V) / R4
    But I don't know the value of R4?
  3. Jony130
    Feb 17, 2009
    3,993
    1,116
    Hey but, your Vcc-pos is 21 V so VB3 voltage is equal to (if we ignore IB3):
    VB3 = 21V - Ic1*R3 = 21V - 1,825 mA*2kΩ1 = 21V - 3.65V = 17.35V
    Also notice that R4 and R5 "set" the Q3 voltage gain.
    I don't understand this ?
  4. Rumination
    Mar 25, 2016
    74
    Yes, you are right. It's 21 V and not 8,8 V. I got confused. But what does this mean:
    "R4 and R5 "set" the Q3 voltage gain"?
    And just ignore, Quiescent current IC = 10 * Q3-Q4 IB.
  5. Jony130
    Feb 17, 2009
    3,993
    1,116
    The Q3 voltage gain at first glance is equal to AvQ3 ≈ R4/R5
  6. Rumination
    Mar 25, 2016
    74
    But I don't know the value of either R4 or R5?
  7. crutschow
    Mar 14, 2008
    13,508
    3,384
    But you know their ratio.
    This is not a single answer to their correct values, only their ratio. You select the value to give the desired Q3 transistor bias current.
    For a real design this current would affect the frequency response which may be of interest.
  8. Rumination
    Mar 25, 2016
    74
    Do you mean:
    Ad = gm * Rd ?
  9. Rumination
    Mar 25, 2016
    74
    Now I have been working on this problem, but I really can't understand:(
  10. Jony130
    Feb 17, 2009
    3,993
    1,116
    You must start at the output. You have been given RL and Vout_max so from there you can find Ic4 and Ic3 quiescent current.
    And choose R4,R5R1,R1 to meet the voltage gain requirement at given quiescent current .
  11. crutschow
    Mar 14, 2008
    13,508
    3,384
    What's Rd?
    No, that gain equation only holds when there is no emitter resistor.
    The emitter resistor provides negative feedback and, for low values of gain (much less than gm*R5), the gain of Q3 is approximately R5/R4.
  12. Rumination
    Mar 25, 2016
    74
    Can I do it like this:
    VB3=17.35V
    We know: VE3=(17.35+0.7)V=21-IC3*R4
    We also know: VB4=+0.7V=-21+IC3*R5.
    So by eliminating IC3 it gives a second equation for R4 and R5:
    18,05 = 21 - R4
    R4 = 2,95
    0,7 + 21 = R5
    R5 = 21,7
    Does it mean, that we have found the values of R4 and R5? And now we can find the value of Ic3?
  13. Rumination
    Mar 25, 2016
    74
    To find Ic3:
    Ic3 = IE3 = (21 V - VBE - 0,7 V) / (R4) = (21 V - 17,35 V - 0,7 V) / (2,95) = 2,95 / 2,95 = 1 mA.
    To find VB4:
    VB4 = -21 V + R5 * Ic3 = -21 V + 21,7 V * 1 mA = 0,7 V.
    Vout = VB4 - 0,7 V = 0 V
    To find Ic4:
    Ic4 = (0 - (-21 V)) / R6
    But I don't know the value of R6.
  14. Jony130
    Feb 17, 2009
    3,993
    1,116
    But what about Vout-min = -8,8 V and RL = 49 Ohm ? Do you have any info about transistor current gain (beta /hfe) ?
    And a tip
    Ask yourself a question, why the output voltage is "clip" at -5V ?
  15. Rumination
    Mar 25, 2016
    74
    Does it mean, that I can find Ic4:
    Ic4 = V / R = 8,8 / 49 = 0,18 mA
  16. Jony130
    Feb 17, 2009
    3,993
    1,116
    Ic4 should be larger than this 0.18mA
  17. Rumination
    Mar 25, 2016
    74
    So what am I doing wrong?
  18. Jony130
    Feb 17, 2009
    3,993
    1,116
    It looks like you do not know (or understand) how to find maximum negative voltage swing at the load for a simply emitter follower circuit (Q4).
  19. Rumination
    Mar 25, 2016
    74
    Yes, you are right. I will try and find it in my book. I will be back.:)
  20. Jony130
    Feb 17, 2009
    3,993
    1,116
    To help you with this problem look again at my post #14 and Ask yourself -- >What voltage at the T1 base will cut-off T1 transistor?
