As I said in my previous post your diagram is a small-signal model for AC signals only. And this model is just a abstract concept.
And the task of this abstract model is to help us analyze this nonlinear circuit using only traditional "linear abstract models" and network theories (Ohms law, kvl, kcl, mesh, nodal etc) based on linear algebra. Also BJT must be properly biased because AC signal will "modulates" this Q point in the "rhythm" of AC input voltage.
See the example
http://forum.allaboutcircuits.com/threads/class-b-push-pull-amplifier.85631/#post-614844
As for your dif amp as input signal voltage rise the Ie1 will also rise but Ie2 will decrease by the same amount.
So we can say that Ie2 is "negative" because Ie2 is now smaller than the Ie2 quiescent current.
http://forum.allaboutcircuits.com/attachments/1-png.30861/ (Q point is Ie1 = Ie2 = 1mA)
But Ie1 and Ie2 will still flow in the same way (into Ree).
See the example
