Differential amplifer frequency responce prediction
Discussion in 'General Electronics Chat' started by Mitchy190, Dec 9, 2012.
  1. Mitchy190
    Apr 23, 2012
    33
    Hey! I was wondering, how would I predict the frequency response of the circuit below when v2 is grounded?
    I have actually measured the response which is also shown below, v2 is grounded.
    I know the input impedance of the circuit and therefore I calculated the frequency response of the capacitor and input impedance, which form an RC circuit.
    This gives the same shape as my measured response which i would expect, but there is an offset, as you can see. I calculated a 'gain' to be around 27-28 which if i were to multiply the transfer function i worked by, the correct offset would occur.
    I have no idea what this is, it cannot not be the Gdm or Gcm of the transistor as i have calculated them and not got 27-28?
    I got:
    Gdm = R4/2*rE = 164, where rE = 25mV/IE = 25mV/1mA
    Gcm = R4/2*R3 = 0.603
    Please could someone check this out? :)
    Schematic diagram of circuit, v2 is grounded:
    Graphs:
    View attachment frequency responses.pdf
  2. #12
    Nov 30, 2010
    16,704
    7,354
    I'm not the expert in this field, but I don't see any capacitors in your math. Frequency limits in this kind of circuit are always about capacitance. Do you know what Miller effect is?
    Mitchy190 likes this.
  3. Mitchy190
    Apr 23, 2012
    33
    I calculated the frequency response by working out the transfer function of the capacitor and the input impedance.
    This attachment to this reply shows what I mean:
    View attachment Figure one shows the input impedance of the circuit.pdf
    So i have taken into account the capacitor, but to answer your question i have not her of that effect? Could this be taken into account for this situation?
  4. Mitchy190
    Apr 23, 2012
    33
    And thank you for your reply! :D
  5. #12
    Nov 30, 2010
    16,704
    7,354
    Miller effect is your problem google "Miller effect".
    Edit: Wrong answer. I thought you were talking about the high end.
  6. Mitchy190
    Apr 23, 2012
    33
    Okay cheers :) I will check that out.
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    Frequency response involves a low frequency cutoff and a high frequency cutoff.
    YOU DID NOT SAY WHICH ONE but later you are talking about the low frequency cutoff which is caused by the value of the input coupling capacitor, the value of R1 parallel to the value of the input impedance of the left transistor and both resistances are in series with the resistance of the signal source.
  8. Mitchy190
    Apr 23, 2012
    33
    Yes I mean the low frequency cut off, which occurs around 100Hz. 1/RC.
    Okay, I don't fully understand what you mean? I know R1 is in parallel with the input impedance.. do you mean when we represent the circuit as its thevenin equivalent, the voltage source is in series with R thevenin (which is input impedance)?
  9. #12
    Nov 30, 2010
    16,704
    7,354
    If you're talking about the low frequency end, my answers are very wrong.
  10. Mitchy190
    Apr 23, 2012
    33
    You see the graph I have put up, one is a graph I measured, by grounding V2, then by varying the frequency and measuring the input and output amplitudes. :)
    Do you know how I would predict this outcome? Or an outcome for this situation? This would be extremely helpful! My attempt at this was to look at the low cut off, but that is wrong, i just can see from this result that the graphs have the same shape.. but the one i measured is shifted up by an amount or a gain? I calculated this to be around 28, and wondered if this number could help me predict the outcome i want.
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    The resistance of the signal source is in series with R1 and the input impedance of the left transistor in parallel.
    If your signal source is from an opamp then the series resistance is almost zero.
  12. Mitchy190
    Apr 23, 2012
    33
    The input signal is a sine wave varied over the frequency 10Hz to 1MHz, this is applied to V1.
