Different loop getting different answers?
Discussion in 'Homework Help' started by hitmen, Sep 22, 2008.
  1. hitmen
    Thread Starter Active Member
    Sep 21, 2008
    159
    I need help with regard to this qns. I am supposed to use Thevenin theorem to find V aross the 8kΩ resistor.
    Note that the voltage across the voltage source is 12V.
    I broke the circuit after the 4kΩ resistor.
    I am now trying to find V ab open circuit.
    Since no current flows through 4kΩ, 2mA flows through 2kΩ resisor.
    I across 6kΩ is (3k)/(9k) * 2mA = 2/3 mA
    I across 3kΩ is 4/3 mA using voltage divider rule.
    PD across 3kΩ is 4V.
    PD across 6kΩ is 4V.
    Here is my qn. If I take the loop across the 12V voltage src, my V ab open circuit will be 4V + 4V + 12V = 20V.
    However, if I take the loop across the 6kΩ resistor, V ab open circuit is 4V + 4V = 8V.
    Where have I gone wrong?
    This problem is adapted from Basic Engineering Circuit Analysis 8th Edition.
  2. mik3
    Feb 4, 2008
    4,846
    63
    The voltage across ab is 8 volts. If you find the thevenin voltage across ab with the voltage divider circuit of the 3K and the 6K resistors then you find 8 volts and a thevenin resistance of 4K.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    I came up with 8 volts just like Mik3
    hgmjr
  4. hitmen
    Sep 21, 2008
    159
    Err.. I am not concerned with the answer. I am more concerned with why I use 2 loops and get different answers. I get 8V for 1 loop and 20V for another.
    Can we use pd divider rule when there is a voltmeter in the circuit?
  5. mik3
    Feb 4, 2008
    4,846
    63
    We assume the voltmeter has a very high input resistance (open circuit) so we can use the voltage divider rule.
    I cant see where did u find the 4+4+12 voltages. Resistor 2K does not determine the thevenin voltage. Think of it.
  6. hitmen
    Sep 21, 2008
    159
    I see. Do you mean to imply that we do not need to add the 12V voltmeter when we determine Vab open circuit. If so, then I understand where I have gone wrong.
