Thank crutschow for your quick reply so if the output of the log circuit connected to completer op amp there is no different between the 2 log circuitsThe op amp converts input voltage to a current source of Vin/R through the diode and provides a low output impedance to drive a load. Otherwise the voltage versus diode current will be the same.
by Duane Benson
by Jake Hertz
by Aaron Carman
