Difference equation of the system
Discussion in 'Homework Help' started by mo2015mo, Mar 3, 2014.
  1. mo2015mo
    May 9, 2013
    157
    Hello my friends,, :)
    I tried to solve the question as written in attached photo,,and I couldn't answer it correctly, ,, please help me to know where's the wrong step(s)?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    I have another answer:
    \text{ Y(n)=-0.3Y(n-1)+8X(n)+6.2X(n-1)}
    So confusion reigns!
    mo2015mo likes this.
  3. WBahn
    Mar 31, 2012
    18,092
    4,918
    Your diagram seems a bit ambiguous to me. For instance, I'm having to guess which end of the delay element is the input and which is the output. I'm guessing that the top is the input and the bottom is the output.
    Is the summing node that is feeding the x4 multiplier summing three terms? More specifically, is the signal at the bottom of that summing node going in or coming out? I'm assuming it's going in.
    Your equations don't seem to mesh up with the diagram very well. You say that Eqn. 3 is -0.3*y[n-1]. But you also say that Eqn. 4 is x[n-1]. Aren't these at odds?
    Your Eqn.2 doesn't reflect that third line coming up into the bottom of the summing block.
    How have you concluded that the signal on the bottom line is y[n-1]?
  4. mo2015mo
    May 9, 2013
    157
    From the past paper exam answer the coorect answer is Y(n)=-0.3Y(n-1)+8X(n)+2.2X(n-1)
    and what is your solution steps u taken??
    I sonsidered that Direct Form II block diagram and solved on it
    where (a) Direct Form I block diagram (b)Direct Form II block diagram
  5. mo2015mo
    May 9, 2013
    157
    I were drawn a wrong line ,, I'm modified this to be as attached photo.. :(
    I'm sorry for that :)
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    In the revised case I obtained the same answer given as being correct.
  7. mo2015mo
    May 9, 2013
    157
    Okay :) .. What's method you solved of it ?? or what is wrong in my solution ??
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    I use a different method so it probably won't be of much use to you. I've attached for your information.
  9. mo2015mo
    May 9, 2013
    157
    yes ,, it seems complex...:eek:
    I have another question requires impulse response and difference equation ,, i solved it by reducing Block Diagram as attached photo,, Is it correct or Non... :confused:
      File size:
      222.7 KB
      19
  10. mo2015mo
    May 9, 2013
    157
    ............. :confused:
