difference betwen maximum output swing and maximum differential output swing??
Discussion in 'The Projects Forum' started by ncj, Sep 20, 2012.
  1. ncj
    Sep 18, 2012
    what is difference betwen maximum output swing and maximum differential output swing??
    plz help
    thanks in advance...
  2. Dodgydave
    Jun 22, 2012
    5,142
    768
    Are we talking about op amps?
  3. ErnieM
    Apr 24, 2011
    7,435
    1,625
    I dunno, I would guess "output swing" is measured from some point called "output" and ground, while "differential output swing" is measured between two points labeled "output" in some fashion.
    I would expect the two points in the latter definition to be the inverse of the other, possible with or without some DC offset.
    Other then that, the questions are pretty meaningless without a context.
    Context is everything!
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    What is a differential output? It is TWO outputs out-of-phase so their differential output voltage swing is double the swing of a single output.
