difference between two mosfets
Discussion in 'The Projects Forum' started by mah, Dec 24, 2013.
  1. mah
    Thread Starter Active Member
    Mar 15, 2010
    276
  2. Griz
    Jun 19, 2013
    5
    Part of the confusion here may be that the IRF250 is an N-Channel device while the IRFP250 is a P-Channel device. As far as a semi-conductor of any type being *IDENTICAL* specifications from different manufacturers, they are close but there could be some slight variations. But, that is why we use data sheets, isn't it?
    As I understand it, MOSFET linearity is usually only viable in a narrow range of gate inputs and that's only due to a slight flattening of the performance curve within those parameters, not to true linearity of the device.
  3. mah
    Mar 15, 2010
    276
    both of them are N-channel mosfet
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    There is no practical difference when using either of these FETS as a voltage variable resistor for MPPT tracing.
    The differences, if any, do not matter when the FET is used in a closed loop opamp circuit where the opamp does whatever is required to set the gate voltage to get the commanded drain current. That is the whole premise of the voltage-driven constant-current sink circuit that we have been discussing here.
    How many threads are you going to start on this topic?
  5. mah
    Mar 15, 2010
    276
    till i get answer for my problem , i hope any body help for this random values on gate and drain of the mosfet . i think there is a modification on the circuit.
  6. shortbus
    Sep 30, 2009
    4,092
    1,673
    Maybe completely off base with this, but wouldn't a Jfet be a better component for this application? Never used one but, aren't they are more for linear use than a Mosfet.
    http://en.wikipedia.org/wiki/JFET
