I currently have a prototype application (simple flyback converter in essence) which functions correctly with the following type of transformer:
It is an auto-transformer being used in flyback mode at 100Hz. It's values are approximately P = 5mH N = 1:4.
I want to switch this type of transformer with the following type of transformer with the same values used in the same application:
This type of transforemr (CCFL) better serves me because of its physical dimensions. I spoke with the manufacturer and it can be produced with the same values. Should I expect my device to continue to work in the same fashion? The only obvious differences I am aware of is the ground isolation (which I don't think should matter here) and the fact that the auto-transformer has extremely low leakage inductance.
Can I expect my device to operate in the same fashion?
Thanks for any reply
