Difference between smart diode and normal diode
Discussion in 'General Electronics Chat' started by rizwan.bashir, Aug 15, 2013.
  1. rizwan.bashir
    Aug 14, 2013
    14
    Has anyone heard about the term "smart diode" used in earth continuity relays?
    What is the difference between a smart diode and a normal diode?
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    Could you throw us a bone and provide a link of some kind to some place where these are mentioned?
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    Could be referring to pilot core protection, such as used in mining operations to respond to faults or damage in trailing power cables.
  4. rizwan.bashir
    Aug 14, 2013
    14
    Yes, they are used in mining sector to check earth continuity. The usual idea is to check earth continuity (look for a diode or smart diode). You send a positive pulse and look for a low voltage because the diode is forward biased and then you send the negative pulse and see open circuit (as the diode is reverse biased). Then you transmit power.
    I know this much but can anyone give me any design/circuit for this smart diode stuff used to check earth continuity for equipments used in mining sector.
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    A "Smart Diode" is one that can log on to the internet. ;)
    Oh hang on, that's an "iDiode".
    :D
    #12 likes this.
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    If a diode is a poem about death, then a smart diode must be a smart poem about death -- right?
    #12 likes this.
  7. rizwan.bashir
    Aug 14, 2013
    14
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    You can either get angry or get smart.
    You were already asked by WBahn to provide some link to where such a smart diode was specifically mentioned.
    You didn't respond. It would help if you were able to provide that information or link. Then you won't have to feel you have been teased.
  9. rizwan.bashir
    Aug 14, 2013
    14
  10. t_n_k
    Mar 6, 2009
    5,448
    783
    The relay data makes no mention of a smart diode. In fact on page 7 the data sheet suggests using a 1N4007 1000V 1A diode. That's an ordinary commonly used silicon diode.
  11. LDC3
    Apr 27, 2013
    920
    160
    It appears that TI produces a "smart diode" for PV panels.
    http://www.ti.com/lit/ds/snvs903/snvs903.pdf
  12. t_n_k
    Mar 6, 2009
    5,448
    783
    No doubt of interest but probably not relevant to the OP's question as they have already indicated the issue is with mining cable pilot wire protection schemes.
