Difference between microSD and SD protocols?
Discussion in 'Embedded Systems and Microcontrollers' started by Razor Concepts, Aug 6, 2010.
  1. Razor Concepts
    Thread Starter Active Member
    Oct 7, 2008
    212
    Hi, I was just wondering if there was a difference between the SPI protocols with microSD and standard sized SD. Thanks!
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What does the specification say? What spec you say. Well it's hard to answer such a question without a copy of the specification so tracking one down should be job #1
  3. Syniva
    Jun 21, 2010
    25
    I tried one once using one of those size-converting cards. Seems to work the same way.
  4. nsaspook
    Aug 27, 2009
    3,009
    2,352
    The difference is between SD and SDHC cards. It's easier to interface with SDHC cards because the data storage protocol is mainly block oriented vice byte for older SD cards.
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Well even the SPI protocol on the SD Cards is Block Oriented so I'm not sure of the relevance of your comment. I think it would be helpful if the OP could articulate his requirements to a deeper level.
  6. nsaspook
    Aug 27, 2009
    3,009
    2,352
    Not really, at the SPI command level SD cards are byte addressed. Most drivers hide this fact at the routine interface level.
    SDHC cards can not be accessed to the byte level the way a SD card can unless you buffer an entire block.
    http://elm-chan.org/docs/mmc/mmc_e.html
    http://www.google.com/url?sa=t&source=web&cd=3&ved=0CBwQFjAC&url=http%3A%2F%2Fwww.freescale.com%2Ffiles%2Fmicrocontrollers%2Fdoc%2Fapp_note%2FAN3805.pdf&ei=d5JcTPLkIIXUtQPw89TUDQ&usg=AFQjCNHCKHHObB2FZu9Uzu5J6BUnLjr1Xg&sig2=v1edeSbbT17mOs8XnACf2A
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I see. So you say the SD Card is "byte addressed" because you can start a transfer at any byte location and read from 1 to N bytes where N may or may not have an upper limit.
    By comparison you seem to be saying that in the SDHC card you can begin only on a sector boundary and you must(?) read the entire sector.
    Did I get that right?
  8. nsaspook
    Aug 27, 2009
    3,009
    2,352
    That's it in a nut shell. For a SD card, N is up to 512 (BLOCK_LEN normally) but a SD cards (READ_BL_LEN) can be up to 2kBytes on large cards. This makes buffer size/capacity calculations a little more complex on a general SD card vs pure SDHC driver.
    http://en.wikipedia.org/wiki/SDHC#Compatibility_issues_with_4.C2.A0GB_and_larger_cards
    http://www.hjreggel.net/cardspeed/special-sd.html
  9. Vaughanabe13
    May 4, 2009
    102
    5
    SD and MicroSD are pin compatible. They are the same, just different physical sizes.
