Difference between linear and switching regulators
Discussion in 'General Electronics Chat' started by RRITESH KAKKAR, Mar 22, 2011.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    What is the difference in linear & switching regulators??
  2. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Please, reply.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    RRITESH KAKKAR likes this.
  4. tom66
    May 9, 2009
    2,613
    214
    A switching regulator transfers charge between an inductor and capacitor at such a rate to increase, decrease or invert a voltage. It works by creating a magnetic field in the inductor and using clever control electronics it regulates the voltage. There are also regulators which use transformers, and technically charge pumps can be considered a type of switching regulator, but using capacitors instead. A good switching regulator will run from about 75% to 90% efficiency. Charge pumps are ideal, approaching 99% efficiency, but output current is often limited to a few hundred mA at best, and switching noise can be an issue.
    A linear regulator works kind of like a series resistor. To drop voltage it dissipates heat. The amount of power wasted, in watts, is approximately (Vin-Vout)*Iout. A linear regulator can ONLY step down voltage.
    Linear regulators are by far easier to design for. However, they can be tricky if they are small - thermal management (keeping it cool) can become a real issue.
    Now, that's not to say a (step-down) switching regulator is more efficient than a linear regulator. In certain circumstances, for example low current drain or a small Vin-Vout differential, an LDO can outperform a switcher. A low dropout regulator dropping 0.5V (from 5.5V to 5V) and delivering 100mA would only dissipate 50mW, to provide 500mW - around 90% efficiency.
