Difference between electric and electronic
Discussion in 'Off-Topic' started by acelectr, Jun 17, 2011.
  1. acelectr
    Aug 28, 2010
    73
    Hi, simple question: what is the difference between electric and electronic. There are bucnh of explanations over the internet which mostly are quite different from each other. So still I don't really know the exact answer to this mystery. It would be great to have a clear and consistent answer to it & thnx for any given contribution to this thread...:rolleyes:
  2. #12
    Nov 30, 2010
    16,705
    7,358
    As far as I know, electronics uses semiconductors and electricians don't.
    You can wire up lots of electrical circuits with motors, lamps, switches, etc. but as soon as a semiconductor gets involved, you're doing electronics. Lots of people can install a light dimmer, but that doesn't make them an electronics designer.
    That's one opinion.
  3. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    If you are talking about electronic engineering vs. electrical engineering, the difference I have heard is that electronics refers to things with semiconductors (as #12 said), and electrical means something like residential, power grid, etc. Electronic is generally low voltage, and electrical is generally high-voltage.
    Just what I've gathered over the years :D
    Der Strom
  4. cjdelphi
    Mar 26, 2009
    272
    electric and electronic...
    Electric powers your device be electronic or otherwise....
    Electronic is merely the ability to control electric/electrons that flow around a circuit... Be that using a semiconductor or via resistive loads, the manipulation of electrons
