Difference between EEPROM and FLASH
Discussion in 'General Electronics Chat' started by Tabur, Dec 20, 2013.
  1. Tabur
    Mar 15, 2012
    5
    Hello!
    I've never used Flash memory directly (without a specific controller/driver), so I don't know much about it. In practice, what's the difference between Flash and EEPROM? I know flash memories are usually bigger than EEPROMs, but besides that, whats different?
    I'm designing a product where I need to store around 1 MBytes of data from time to time, and I've only used EEPROMs thus far, so I'm thinking about working with flash memories.
    Thanks!
  2. GopherT
    Nov 23, 2012
    6,300
    4,020
    See first three paragraphs here...
    http://en.wikipedia.org
  3. Tabur
    Mar 15, 2012
    5
    But the thing is, that's not right. Most EEPROMs nowadays have byte write/byte erase capabilities.
    What's the practical difference between both?
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
  5. Tabur
    Mar 15, 2012
    5
    Ty bertus!!! Nice documents!
    Although I was looking more for a 2 phrase explanation. I think one of the biggest differences is that most flash run at 2.7v while eeproms at 5v, and flash tend to be bigger
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It's just branding. The general public can say "flash", even the stupid ones.
  7. cabraham
    Oct 29, 2011
    82
    30
    EEPROM is byte erasable. Each address bit can be erased and reprogrammed independently. Flash is block erasable. Sections called blocks must be bulk erased then reprogrammed. Some flash parts have "boot blocks" where some blocks are smaller than the rest. This allows a small section to be erased and rewritten. Other parts have uniform blocks, all equal.
    Flash writes faster, typically in usec. But EE write time is typically msec. Big speed difference, hence the name "flash". I've worked with both for decades and these are my off the cuff comparisons.
    Claude
    absf likes this.
