Difference between a Bus and an Interface
Abhinavrajan
Joined Aug 7, 2016
83
I would like to know the difference between a Bus and an Interface.
An interface is basically a bus, right ?
Consider this example where I have microcontroller connected to a temperature sensor via an I2C bus.
They communicate via the I2C interface.
Inside the microcontroller, what protocol does the Control, Address and Data Bus follow ( Like whether they follow the I2C protocol, SPI protocol ) ?
They data from the microcontroller moves through the data bus to the I2C interface. What protocol does the Data bus follow or what is the difference between the I2C bus and the data bus ( Which is present inside the microcontroller )
I am just a beginner in electronics. So, I don't understand concepts clearly when said for the first time. Simple english with an example would really help me.
Please send me any good links or PDFs on these topics i.e. Buses, Interfaces which can give me some really good clarity for a beginner.
Thank you.
hp1729
Joined Nov 23, 2015
2,304
Thank you.
Lets' go way basic and we can talk about the 5V BUS. It's any place that 5V exists.
A BUS BAR does what?
Wit simple memory, you have address its like An, An-1....A0. Each of these addresses e.g. A0 etc. is tied together for each chip, The NOT ENABLE signal generally becomes a CS or Chip Select). So, the "Interface" to this memory module includes the timing and set-up times that need to be present to talk to memory.
You can have interfaces without busses. RS232 is an example although we have introduce Protocol too, The "Interface" is how RS232 is defined, the Protocol would include start, stop bits, parity, data bits and commands to given devices.
RS485 is master/slave bus arrangement.
So, BUS is more of a common element,
Interface is more an electrical definition. We might say our computer has a USB interface or Port.
I'm not sure what to call things like L/R Audio, Composite video, SPDIF optical, Coax optical or even 120/240 volt power cord.
We can also talk about the "User interface" or HMI (Human Machine Interface), so it's not just electrical.
