Difference between 330 (33pF) and 331 (330pF) capacitor markings
Discussion in 'Homework Help' started by StephenDJ, May 12, 2015.
  1. StephenDJ
    Thread Starter Active Member
    May 31, 2008
    58
    This may look confusing, but the one on the right is marked 330 as if the zero should not be included in the value of the cap, right? If the zero means 33 x (10 to the power of zero), then there should not be 330 pF, but 33pF, correct?
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
  3. MikeML
    Oct 2, 2009
    5,450
    1,066
    I have a lot of capacitors around here that are marked 330 that are actually 330pF. That is why I own one of these:
    aade.com
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    I agree. When it will make a difference, check -- not unlike confirming the fuel in your airplane. Standards change, and you can never be absolutely certain whether something is labeled according to the most current standard.
    John
  5. atferrari
    Jan 6, 2004
    2,663
    783
    That I recall, I've been lucky. I never run across the "330" type but always "33". But, good to keep in mind.
  6. StephenDJ
    May 31, 2008
    58
    Thanks everyone. I was sorting my parts bin, and came across these. So are you telling me what I have in my bin may actually be 330pF? I have no way to check them. Just wanted to make sure they wind up in the right cabinet drawer.
  7. WBahn
    Mar 31, 2012
    18,085
    4,917
    You have lots of ways to check them, depending on what you have available. Do you have an oscilloscope? If so, then make a little RC circuit using 1MΩ resistors and measure the time constant. If you have some basic digital parts then you can make any number of oscillator circuits that go into a frequency divider with enough stages to blink an LED as a slow enough rate for you to visually tell the difference between 1Hz and 10Hz, for example.
  8. WBahn
    Mar 31, 2012
    18,085
    4,917
    There's a current standard for capacitor marking? :D
  9. StephenDJ
    May 31, 2008
    58
    Good idea. Yes, I have a 20Mhz oscilloscope. Since I'm just now getting started back on electronics and getting my workbence in order, I may check this later. But I think I could use t=RC at which V=70% of peek to confirm this value. Or I could do it by reactance measurements using X=1/(2piFC).
  10. RichardO
    May 4, 2013
    1,335
    429
    It seems that if the value has a tolerance then the value is in picofarads (no multiplier digit). If not then the value is digit,digit,multiplier (also in picofarads).
    Rant: I hate cap markings.
