Difference Amplifier Simulation PSPICE
Discussion in 'Homework Help' started by emr0327, Sep 22, 2016.
  1. emr0327
    Sep 22, 2016
    10
    Hi, I am stuck on this problem where I need to plot the input and output waves. I also do not know how to simulate the 180 degree out of phase shift of v2. I have attatched both the questions and my PSPICE circuit.
  2. crutschow
    Mar 14, 2008
    13,529
    3,393
    The 741 cannot drive a 50 ohm feedback resistor.
    It should be at least 2k ohm.
    The calculated gain of that circuit is -R2/R1 = -.05 (ignoring the problem in the next paragraph).
    I assume you want a gain of 20.(?)
    Why do you have the output connected to ground? :confused:
    With that your gain will obviously be zero.
  3. emr0327
    Sep 22, 2016
    10
  4. emr0327
    Sep 22, 2016
    10
    After careful calculations I see now that R2=R4=10k. The gain of the circuit must be 10 V/V.
    I do not understand what the prompt means when it says the input voltages must have an output resistance of ohm. How can I represent that in the simulation?
    When I take out the GND from the output, I do not get a 50 mV pk-pk waveform.
  5. JoeJester
    Apr 26, 2005
    3,403
    1,230
    How do you represent the internal resistance of a battery?
    The same way you represented Ri of a battery on paper is the same way you represent Ri of any signal source in the simulators.
    The circuit drawings are the same whether you are using paper and pencil or a simulation program.
  6. crutschow
    Mar 14, 2008
    13,529
    3,393
    With GND on the output, the output must be zero.
    How can it be otherwise?
  7. emr0327
    Sep 22, 2016
    10
    I believe this is the correct way to represent the output resistance. Can you please confirm or deny this for me? I cannot assume that the resistance would go in series with R3 or R1. So the only other place is in the output node.
  8. crutschow
    Mar 14, 2008
    13,529
    3,393
    A 741 cannot drive a 50 ohm load.
  9. emr0327
    Sep 22, 2016
    10
    I agree. The drawing sketches make it seem that I must connect the output to ground, but I understand now why that cannot be done. I was thinking of it more as an open circuit, but I know that that is virtual and should not be schematically represented that way.
    Can you please help me in how I can simulate the 180 degree out of phase shift of v2.
  10. emr0327
    Sep 22, 2016
    10
    I do not understand then where to put the 50 ohm resistor.
  11. JoeJester
    Apr 26, 2005
    3,403
    1,230
    What does your instruction say about the 50 ohm resistor?
  12. emr0327
    Sep 22, 2016
    10
  13. JoeJester
    Apr 26, 2005
    3,403
    1,230
    I've read that. I want you to tell me what it says. I know what it says.
    emr0327 likes this.
  14. crutschow
    Mar 14, 2008
    13,529
    3,393
    We'll help you do the simulation you first need to understand the circuit.
    It makes no sense to try to simulate a circuit you don't.
    Learning is not turning a crank to get an answer.
    Do you know what "input voltage source" means?
  15. emr0327
    Sep 22, 2016
    10
    Yes, the input voltage sources are labeled V1 and V2 on my schematic. It represents the voltage that is going into the circuit.
  16. emr0327
    Sep 22, 2016
    10
    It states that the output resistance for VI1 and VI2 is 50 ohm. Meaning, when a voltage is inputted into the circuit, the output resistance will read 50 ohm. Reading this I am confused if it is asking to change the resistors right after the input voltage sources to 50 ohm or if it's asking to put resistors near the output.
  17. JoeJester
    Apr 26, 2005
    3,403
    1,230
    After you designed your circuit, then hook up the sources and their load.
  18. emr0327
    Sep 22, 2016
    10
    Ohhh okay I understand it now. The resistor is connected with the input voltage sources as depicted in the attached illustration.
  19. JoeJester
    Apr 26, 2005
    3,403
    1,230
    either side of the source would be correct.
