Diff. eq.
Discussion in 'Math' started by boks, Nov 27, 2008.
  1. boks
    Thread Starter Active Member
    Oct 10, 2008
    218
    1. The problem statement, all variables and given/known data
    The function u(x,t) satisfies the equation
    (1) u_{xx} = u_{tt} for 0 < x < pi, t > 0
    and the boundary conditions
    (2) u_x(0,t) = u_x(pi, t) = 0
    Show that (1) and (2) satisfy the superposition principle.
    2. The attempt at a solution
    I let w(x,t) = au(x,t) + bv(x,t) for two constants a and b.
    w_{tt} = au_{tt} + bv_{tt} = au_{xx} + bv_{xx} = cw_{xx}, where c is a constant
    Have I now showed that w(x,t) satisfies (1)? w_{xx} is not equal to w_{tt} unless c is 1...
  2. blazedaces
    Jul 24, 2008
    130
    You have not shown that w(x,t) satisfies (1). May I ask what "w_{xx} is not equal to w_{tt} unless c is 1..." have to do with the superposition principle?
    The part that is going about it correctly is when you do the following: "au_{tt} + bv_{tt} = au_{xx} + bv_{xx}". But you need to prove that to be true, you can't just write it down...
    By the way, are you studying waves at the moment, because part 1 is part of the definition of a wave...
    -blazed
  3. boks
    Oct 10, 2008
    218
    I figured it out, thanks.
    I'm studying PDEs.
  4. blazedaces
    Jul 24, 2008
    130
    I see. That's good.
    Cheers,
    -blazed
