Diff Amp minimum detectable input
Discussion in 'General Electronics Chat' started by JeremyB, Oct 2, 2012.
  1. JeremyB
    Jul 22, 2012
    8
    Hi guys,
    I'm looking for a diff amp that can detect the difference of 1uV across it's +/- inputs. The problem is that I'm not very familiar with diff amp specs so I'm not sure what to look for exactly. Help would be greatly appreciated.
    Application: ac current sensing
    Thanks,
    Jeremy
  2. Ron H
    Apr 14, 2005
    7,050
    657
    Why is your signal so small?
    How much gain do you need?
  3. crutschow
    Mar 14, 2008
    13,522
    3,390
    You would need a low-noise amp such as the OP-07. What is the AC frequency?
  4. ssnyde
    Apr 4, 2012
    19
    5
    Google instrumentation amp. Buy a single chip one with low noise, don't build one from op amps. Use a second stage for more amplification. If your using a current shunt resistor increase the value so your input isn't so low.
  5. ramancini8
    Member
    Jul 18, 2012
    447
    119
    You are not going to find it easy to sense 1Uv with a diff amp because just the circuit board wiring can create that much voltage from noise or thermal effects. Look real hard at amplifying the signal first because the judicious use of filters can improve the signal to noise ratio. You must break the signal down into its frequency components before you select or design the filters.
