Diff Amp Biasing Problem
Discussion in 'General Electronics Chat' started by mr_ivoryz, Jan 18, 2012.
  1. mr_ivoryz
    Nov 19, 2011
    8
    I am trying to figure out why there is 2.55mA running through the drain of M1, it should not be there....also I noticed that I have a "gate" current which should not be there also....
    I am using the The 50nm MOSFET models found at http://cmosedu.com/cmos1/cmosedu_models.txt
    The currents out of the Source of M1 & M2 are negative, due to LTspice's definition, but they are flowing the correct way.
    Does anybody know what I am doing wrong? Is their something wrong with my circuit design/DC Biasing?
  2. Adjuster
    Dec 26, 2010
    2,147
    300
    Check the voltages at the source connections of M1 and M2. If the 20A μcurrent source I2 that feeds them is pulling them below ground (substrate) potential, you might get leakage into the substrate connections of the FETs.
    Oh dear, my mistake, brain fart, completely wrong, the source potentials are OK - so I've no clue: sorry.
  3. mr_ivoryz
    Nov 19, 2011
    8
    Yeah, I thought they were ok too...I still cant figure this out, if anyone else has any input, please let me know!
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    Add LTspice simulation file
  5. mr_ivoryz
    Nov 19, 2011
    8
  6. Jony130
    Feb 17, 2009
    3,993
    1,116
    This strange behavior is a results of you MOSFET model.
    Simply reduce the supply voltage to 3.3V and then everything returns to normal. So for 5V Vdd we have some strange breakdown between drain and substrate (body).
  7. mr_ivoryz
    Nov 19, 2011
    8
    Thanks for the help, Ive been trying to figure this out for a little while now....I should of played around with the supply voltage more, I never went lower than 5V.
    I got one more question, is there a better MOSFET model that I should be using? If so, where can I get it?
  8. Jony130
    Feb 17, 2009
    3,993
    1,116
    It all depends on what circuit you want to simulate.
    mr_ivoryz likes this.
