Did someone used a NE568A monolithic phase-locked loop integrated circuit
Discussion in 'The Projects Forum' started by nenadilic84, Aug 18, 2009.
  1. nenadilic84
    Thread Starter Active Member
    Aug 7, 2009
    62
    I'm trying to build a PWM that can oscillate at higher frequencies, from 1Hz to about 50MHz, with adjustable duty cycle of course, and I found a data sheet for NE568 integrated circuit that says that this chip can produce this pulses. Problem here is that I'm not familiar with this chip, I worked with 555 and 558, so does some one has any experience on this.
    Thx,
    Nenad
  2. jj_alukkas
    Distinguished Member
    Jan 8, 2009
    751
    5
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    I don't think the LM567 goes to 50 MHz.
    Can you say more about your application and why you need such a wide range of frequencies?
    John
  4. nenadilic84
    Aug 7, 2009
    62
    I would like to build a signal generator.... For testing purpose...
    No the 567 just go to 500KHz, and I want more :)
    Thx,
    Nenad
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    So how does PWM relate to PPL? Are you wanting to create a square wave that goes to 50Mhz?
  6. nenadilic84
    Aug 7, 2009
    62
    I thought that is related because in the data sheet says that duty cycle can be adjusted, but I didn't figure it out how.
    Yes I need a pulse generator to that can be adjustable lets say from 1KHz to something about 50Mhz.... Is it possible to made such a circuit???
  7. jj_alukkas
    Jan 8, 2009
    751
    5
    Sine or Square ?
  8. nenadilic84
    Aug 7, 2009
    62
    Square... :)
