Since not all of us work with electronics all day every day I thought I would share a bit of what I do on the side.
Here is the multi fuel boiler system I have been working on for my brother over the last few months and just got the main boiler assy finished.
The dimensions are 42" wide by 60" long by ~96" high to the top of the stack.
The burner box is 28" square by 54" deep.
The overall working water capacity was designed to be around 250 gallons.
Total empty weight going by my forklifts lifting capacity is about one ton and its made entirely out of 5/32" 3/26" and 1/4" Hardox 450 high strength steel.
I figure I burned up about 45#'s of high strength E70 .035" welding wire putting it together.
He plans to put a fully insulated outer shell put on it and set it between the two buildings behind it the third picture with the intention to use it to heat the building on the left plus run lines up to his house and garage, that can be seen in the background of the fourth picture, next year.
