Can you guys help double check my work? sorry for using first grader schematics and drawing skills, but its the best i got so bear with me.
Red line is live/hot wire that is daisy chained to all four.
Green line is ground wire daisy chained to all four
White line is neutral that goes from wall split into 8 going to "Slot A" in Relay
Yellow Line is going from silver screw of all 8 receptacles to "Slot B" in Relay (broke break out fin on all neutral sides)
So what do you think? Did I do this correctly? (look into the relay slots being correct and also if the power from wall is safe and correct and anything else i am unaware of. please :-D !!!!!! )
