Did I err when measuring Amp draw?
Discussion in 'General Electronics Chat' started by Cliff987, Oct 27, 2013.
  1. Cliff987
    Oct 2, 2012
    10
    I hooked up my multimeter to measure amp draw for my 240 VAC far infra red heat panels
    I measured 2.31 amps for each panel
    However did I err by not multiplying the 2.31 by 2 because it is 240 and I have two hot leads and no neutral?
    Or stated another way:
    When measuring one conductor to a 240 appliance testing for amp draw, should I double the reading from the one conductor to compensate for the other hot conductor?
  2. #12
    Nov 30, 2010
    16,705
    7,355
    No. The math using 240V accounts for the current flowing in both sides of the 240 line.
  3. Cliff987
    Oct 2, 2012
    10
    thanks. I have only two of these panels, but if I like the way they work I'll get more and run 'em on the same circuit. So calculating load is important.
