So I bought a 3Com 120V AC 60hz 22W to 24V DC 600mA and also bought a 2.5mm mono jack for a device that requires a positive tip 24V DC adapter.
I made sure the readings were less than 25V before soldering the jack. It was around 19-20V.
After soldering the jack, the voltage output was less than 0.5V...
I removed the soldered jack and tested the power adapter directly and the reading on the cables are still less than 0.5V
I didn't notice and weird smell, the power adapter does not get any hotter than it should be I don't understand what happened or what to do with this.
Any idea ?
Thanks !
Any idea ?
Thanks !
