My computer is not working. I suspect that 2 fan heaters on the same multiplug board has damaged the power supply or worse. What can I expect please.
The draw off of a typical 4-way would not care what order the devices were plugged in. When you use a splitter, you are still using 1 circuit from the panel.Thanks for your reply. I live in the uk. There were two fan heaters on the 4 plug in line adaptor and the computer plug was the first,,, I made a mistake there because I thought that if the computer plug was the last plug and the fan heaters were the first two (which incidentally were thermerstatically controlled going off and on all the time) it would not affect the computer. But somehow I put the computer plug before the fan heaters on the circuit which I would think naturally would draw the 4000w ththrough the computer plug. Would that be correct?
