Diagram Explainition
Discussion in 'Homework Help' started by Ponyboy, Mar 1, 2014.
  1. Ponyboy
    Jan 26, 2014
    6
    [​IMG][​IMG]
    In this I am not sure what J21 and J1 are. Like what exactly do they stand for?[​IMG]
  2. paulktreg
    Distinguished Member
    Jun 2, 2008
    625
    125
    Your image isn't showing and won't open!
  3. shteii01
    Feb 19, 2010
    3,518
    515
    Connectors. One is 4 millimeters, other is 2 millimeters.
  4. WBahn
    Mar 31, 2012
    18,093
    4,920
    The "J" designator generally means "Jack", while a "P" designation generally means "Plug". So the diagram for the other part of this equipment would either have a part with a "P" designation, which would mean that it is intended to plug directly into this part (possibly via a permanently mounted cable that has a plug on the end of it) or something with a "J" designation which would imply that there would be a separate cable that connects the two. The diagram for the cable would likely have a "P" designated component on both ends.
    And you must always keep in mind that all of these are conventions and rules of thumb that are adhered to and ignored in varying degrees all the time.
