Diagnosis of Marshall 8100 Valvestate head problems
Discussion in 'General Electronics Chat' started by HawkDogger, Mar 16, 2015.
  1. HawkDogger
    Mar 16, 2015
    Hi Bertus, great response to the very amp I'm working on/trying to understand. I understand your voltage divider calculations but when I use a voltmeter to take readings at R117,118 and 116 I get very low readings. .007 vdc. I thought that maybe the transistor wasn't turned on so I put a 1khz signal through amp and also played my guitar through but very little change. The amps works great so perhaps it's my measuring technique. I measured from one side of the resistors to ground and also across but nothing like the 1.92 volts from your calculation. What am I missing? Thanks.
    e
  2. MrChips
    Oct 2, 2009
    12,657
    3,461
  3. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    In normal operation, the voltage will be low.
    The transistor will only be activated when an overcurrent situation occurs.
    Bertus
