Hi, new member trying to repair a Jazfit T45 treadmill that I picked up for free. I am somewhat experienced at troubleshooting and repairing some electronics, but nowhere near being an engineer. Thanks to anyone who can help.
Fault description: no belt movement. When the start button for belt movement is pressed, the relay on the power control board clicks. Manually moving the belt at this time doesn't help it get going. The belt moves freely manually, and the motor runs the belt fine using an external DC source. Control console and motorized incline both work fine.
Output to motor reads ~3VDC when the start button is pressed. The LED near the large capacitor glows at around half brightness whenever the main power is turned on.
I haven't been able to locate the manufacturer, and a replacement board seems to be unavailable. Schematic is also unavailable, but I will draw one out from the board if I have to.
Aside from replacing the large capacitor, I've targeted the output components first ... advice is welcome though if other components are known to cause problems.
Referring to the pictures below, my biggest problem is identifying and sourcing some of the components attached to the heat sink (edit: the middle one was unsoldered in the picture if you're wondering). The one on the left shouldn't be too hard; information seemed fairly easy to find for it, but comments about it are of course welcome.
I ~think~ the G80N60 in the middle is the same as this. If so, then I have a source for that one. If there might be issues, please let me know. The one in the link is an IGBT, which I don't believe I have the tools to test, but it's only $11 so I'm willing to spend that anyway.
The last one on the right is the sticky one. Nobody here in Australia seems to be able to reference it. The datasheets here seem to match(?) but I don't know how to find any equivalents, other than perusing data sheets for compatible specs. If that's what I need to do then I might have to do it, but does anyone here have any better ideas?
Thanks again for any help. I'll aim to stick around and offer the community any help I can after this.
