Diac?
Discussion in 'The Projects Forum' started by takeitapart, Feb 7, 2011.
  1. takeitapart
    Jun 20, 2010
    21
    I have been working on a project that calls for a Vbr 28volt Ibr 1ma Diac. I cannot seem to locate such a beast. I usually hear "have not seen a Diac in a long time". Is there such a thing as alternative work around/
  2. takeitapart
    Jun 20, 2010
    21
    forgot to mention this is DC circuit
  3. mik3
    Feb 4, 2008
    4,846
    63
    How about a zener diode?
    What will be its use?
  4. Adjuster
    Dec 26, 2010
    2,147
    300
    The diac has a snap-action breakdown characteristic which is different from that of a zener diode. We would really need to know more about the OPs circuit to judge what might work in this application.
    @takeitapart: Could you please describe your application, and post a schematic?
  5. takeitapart
    Jun 20, 2010
    21
    It is for a DC motor control
  6. Bernard
    Aug 7, 2008
    4,240
    414
    NTE6407, 28V break down. NTE tel 973-748-5089
  7. thatoneguy
    Feb 19, 2009
    6,357
    718
    That will only work with rectified AC (unfiltered). If your input is from a battery, it won't work, in case you were going to try that route.
  8. Bernard
    Aug 7, 2008
    4,240
    414
    It is full wave rectified 120, un filtered.
