DHT11 SENSOR with PIC16f877a
Discussion in 'Embedded Systems and Microcontrollers' started by RRITESH KAKKAR, Jul 15, 2015.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    How to a Display humidity sensor DHT11 on leds?
  2. nerdegutta
    Dec 15, 2009
    2,565
    805
    First you need to draw a schematic with headers for a DHT11, socket for you PIC, and some kind of display. When you say you want to display humidity sensor on leds, what exactly do you mean?5mm LED or 7-segments?
    You'd better start with a schematic drawing.
    Remember: "First comes the hardware, then comes the software."
  3. John P
    Oct 14, 2008
    1,637
    225
    How are you doing with that round graphical LED display that makes patterns, Rritesh?
  4. ericgibbs
    Jan 29, 2010
    2,581
    389
    hi Ritesh,
    Look at the DHT22 sensor, it has a superior specification compared to the DHT11.
  5. theonewho
    Jul 9, 2015
    17
    Your question is poorly specified. Perhaps this similar post can help you formulate a better question: DHT11 Sensor
  6. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    The sensor with 7 segment. there is 3 pin sensor of 40 bits data according to data sheet.
    not build right now!
  7. nerdegutta
    Dec 15, 2009
    2,565
    805
    What datasheet?
    Please attach one. I got some DHT11, and they do not have any 7-segments.
  8. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I mean to say that the DHT11 is to be connected with micro and micro will display the Humidity on it.
    how to do communication process?
  9. nerdegutta
    Dec 15, 2009
    2,565
    805
    Like this:
    Here I have used a 2x16 LCD display. If you see page 3 in the attached datasheet, you'll see the schematic diagram. Further down the document, you'll see how to communicate.
    My picture are using an ATmega168... :(
    RRITESH KAKKAR likes this.
  10. ericgibbs
    Jan 29, 2010
    2,581
    389
    theonewho likes this.
  11. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    What is difference between integers and decimal data
  12. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    In this link..
    http://embedded-lab.com/blog/?p=4333
    Code (C):
    1. // LCD module connections sbit LCD_RS at RB2_bit; sbit LCD_EN at RB3_bit; sbit LCD_D4 at RB4_bit; sbit LCD_D5 at RB5_bit; sbit LCD_D6 at RB6_bit; sbit LCD_D7 at RB7_bit; sbit LCD_RS_Direction at TRISB2_bit; sbit LCD_EN_Direction at TRISB3_bit; sbit LCD_D4_Direction at TRISB4_bit; sbit LCD_D5_Direction at TRISB5_bit; sbit LCD_D6_Direction at TRISB6_bit; sbit LCD_D7_Direction at TRISB7_bit;   sbit Data at RA0_bit; sbit DataDir at TRISA0_bit; char message1[] = "Temp = 00.0 C"; char message2[] = "RH = 00.0 %"; unsigned short TOUT = 0, CheckSum, i; unsigned short T_Byte1, T_Byte2, RH_Byte1, RH_Byte2;   void StartSignal(){ DataDir = 0; // Data port is output Data = 0; Delay_ms(25); // Low for at least 18us Data = 1; Delay_us(30); // High for 20-40 us DataDir = 1; // Data port is input   }   unsigned short CheckResponse(){ TOUT = 0; TMR2 = 0; T2CON.TMR2ON = 1; // Start TMR2 while waiting for sensor response while(!Data && !TOUT); // If there's no response within 256us, the Timer2 overflows if (TOUT) return 0; // and exit else { TMR2 = 0; while(Data && !TOUT); if (TOUT) return 0; else { T2CON.TMR2ON = 0; return 1; } } }   unsigned short ReadByte(){ unsigned short num = 0, t; DataDir = 1; for (i=0; i<8; i++){ while(!Data); TMR2 = 0; T2CON.TMR2ON = 1; // Start TMR2 from 0 when a low to high data pulse while(Data); // is detected, and wait until it falls low again. T2CON.TMR2ON = 0; // Stop the TMR2 when the data pulse falls low. if(TMR2 > 40) num |= 1<<(7-i); // If time > 40us, Data is 1 } return num; }   void interrupt(){ if(PIR1.TMR2IF){ TOUT = 1; T2CON.TMR2ON = 0; // stop timer PIR1.TMR2IF = 0; // Clear TMR0 interrupt flag } }   void main() { unsigned short check; TRISB = 0b00000000; PORTB = 0; TRISA = 0b00100001; CMCON = 7; INTCON.GIE = 1; //Enable global interrupt INTCON.PEIE = 1; //Enable peripheral interrupt // Configure Timer2 module PIE1.TMR2IE = 1; // Enable Timer2 interrupt T2CON = 0; // Prescaler 1:1, and Timer2 is off initially PIR1.TMR2IF =0; // Clear TMR INT Flag bit TMR2 = 0; Lcd_Init(); Lcd_Cmd(_Lcd_Clear); Lcd_Cmd(_LCD_CURSOR_OFF);   do { Delay_ms(1000); StartSignal(); check = CheckResponse(); if (!check) { Lcd_Cmd(_Lcd_Clear); Lcd_Out(1, 1, "No response"); Lcd_Out(2, 1, "from the sensor"); } else{   RH_Byte1 = ReadByte(); RH_Byte2 = ReadByte(); T_Byte1 = ReadByte(); T_Byte2 = ReadByte(); CheckSum = ReadByte(); // Check for error in Data reception if (CheckSum == ((RH_Byte1 + RH_Byte2 + T_Byte1 + T_Byte2) & 0xFF)) { message1[7] = T_Byte1/10 + 48; message1[8] = T_Byte1%10 + 48; message1[10] = T_Byte2/10 + 48; message2[7] = RH_Byte1/10 + 48; message2[8] = RH_Byte1%10 + 48; message2[10] = RH_Byte2/10 + 48; message1[11] = 223; // Degree symbol Lcd_Cmd(_Lcd_Clear); Lcd_Out(1, 1, message1); Lcd_Out(2, 1, message2); }   else{ Lcd_Cmd(_Lcd_Clear); Lcd_Out(1, 1, "Checksum Error!"); Lcd_Out(2, 1, "Trying Again ..."); } }   }while(1); - See more at: http://embedded-lab.com/blog/?p=4333#sthash.K0Vlw2cl.dpuf
  13. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    sbit Data at RB0_bit;
    sbit DataDir at TRISB0_bit;
    unsigned short k;
    char temp[] = "Temperature is 00.0 C";
    char hum[] = "Humidity is 00.0 %";
    void DHT11StartSignal(){
    DataDir = 0;
    Data = 0;
    Delay_ms(25);
    Data = 1;
    Delay_us(30);
    DataDir = 1;
    unsigned short DHT11CheckResponse(){
    k = 150;
    while(!Data){
    Delay_us(2);
    k--;
    if(k<1) return 0; // time out
    k = 150;
    while(Data){
    Delay_us(2);
    k--;
    return 1;
    unsigned short DHT11ReadByte(){
    int i;
    unsigned short num = 0;
    DataDir = 1;
    while(!Data);
    Delay_us(40);
    if(Data) num |= 1<<(7-i);
    while(Data);
    return num;
    void main() {
    UART1_Init(9600);
    TRISC.RC0 = 0;
    TRISC.RC1 = 0;
    TRISC.RC2 = 0;
    while(1){
    DHT11StartSignal();
    if(!DHT11CheckResponse()) continue;
    RH_Byte1 = DHT11ReadByte();
    RH_Byte2 = DHT11ReadByte();
    T_Byte1 = DHT11ReadByte();
    T_Byte2 = DHT11ReadByte();
    DHT11ReadByte(); /* Checksum */
    // Set temp
    temp[15] = T_Byte1/10 + 48;
    temp[16] = T_Byte1%10 + 48;
    temp[18] = T_Byte2/10 + 48;
    UART1_Write_Text(temp);
    UART1_Write(10);
    UART1_Write(13);
    // Set hum
    hum[12] = RH_Byte1/10 + 48;
    hum[13] = RH_Byte1%10 + 48;
    hum[15] = RH_Byte2/10 + 48;
    UART1_Write_Text(hum);
    UART1_Write(10);
    UART1_Write(13);
    UART1_Write(10);
    UART1_Write(13);
    PORTC.RC0 = (RH_Byte1) >= 20;
    PORTC.RC1 = (RH_Byte1) >= 30;
    PORTC.RC2 = (RH_Byte1) >= 40;
    // Wait
    Delay_ms(1000);
  14. nerdegutta
    Dec 15, 2009
    2,565
    805
    I thought you were using MPLAB X?
    From the link above:
  15. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I have taken from internet, that's re not my codes...
    i need for mplab x yes.
  16. nerdegutta
    Dec 15, 2009
    2,565
    805
    What does your code look like?
    Do you have a schematic layout?
  17. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I have no schematic first i am working on code because schematic is just power the sensor and connect the data to any port pin.
  18. nerdegutta
    Dec 15, 2009
    2,565
    805
    It is better to do it the other way.
    First make the hardware, then make the software. Be sure to consult the datasheet when making the hardware.
  19. nerdegutta
    Dec 15, 2009
    2,565
    805
    I belive that you are able to go through the code, line by line, and convert it to suit your setup. I belive it is MPLAB X, with XC8 compiler, and a PIC 16F877?
    With help from this link, I was able to make it happen on my 16F628.
    Upper LCD: ATMEL 168. I used the including libraries and one found online.
    Lower: PIC16F628. I used the link TS provided, and converted all the lines to match my setup. MPLAB X v3.05, XC8 v1.34, DHT11 and 2x16 5x7 LCD.
    Good luck.
