Dg303 ac j
Discussion in 'General Electronics Chat' started by saranya ajesh, Oct 10, 2011.
  1. saranya ajesh
    Sep 26, 2011
    Hi all...
    I have to work with the IC-'DG303 AC J'.
    How can we check whether this IC is working or not?
    What is its working principle?
    Regards,
    SaranyaAjesh
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    Can you explain "I have to work with the IC-'DG303 AC J'."?
    For starters you look up the datasheet with Google:
    DG303ACJ
    Set up a test circuit with the appropriate supply voltages, apply the appropriate logic level inputs and measure the continuity of the output switches as you change the logic.
    Ken
