Dewalt drill switch
Discussion in 'General Electronics Chat' started by Gdrumm, Nov 5, 2011.
  1. Gdrumm
    Thread Starter Distinguished Member
    Aug 29, 2008
    684
    36
    I bought a broken Garage sale Dewalt 3/8" drill, D21008 for $2.00
    Checked everything out, and it's the switch.
    I took the switch apart, and cleaned it...,no luck.
    It did try to go a couple of times, but then seemed to run out of juice.
    It has a small board inside, with tiny electronics.
    I've never seen a drill with a board and electronics in the switch before.
    It's a 110v corded drill
    A new switch is like $23.44 from Dewalt, and I don't want to spend that kind of money. Would a bad diode on the board create that symptom?
    Thanks,
    Gary
  2. Gdrumm
    Aug 29, 2008
    684
    36
    Never mind.
    I took the switch apart again and found that the board is cracked.
    As a matter of fact, it is completely broken in half.
    Guess I've got another drill for Parts.
    Gary
  3. strantor
    Oct 3, 2010
    4,302
    1,989
    I'm assuming the drill has multiple speeds & reverse? if so, I'm guessing that's probably what the board is for. you might be able to bypass it and run the mains straight to the motor and a "working, but single speed, single direction" drill.
  4. someonesdad
    Jul 7, 2009
    1,585
    141
    I don't know the drill, but $25 for a usable drill doesn't sound too bad. I've got a Dewalt 3/8" VSR that I've used quite a bit for 20 years without a lick of trouble (just out grinding paint off the garage door day before yesterday, but yesterday it snowed, dammit). I also have an identical one a friend bought and never used, then gave to me when he moved across country.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    You could also put the two halves back together and use short jumper wires to bridge the cracks.
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    That's how I'd solve it if it was a use it or toss it situation. Soldering iron, super glue for the board, tinned copper wire, and solder is all you need. Well, that and a little time.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You have to figure that if the board was cracked, it was under some stress that it wasn't designed for.
    Maybe you can replicate the circuit board, and transfer the components over to the new one.
    [eta]
    By the way, this is post #20,000 for me.
  8. t06afre
    May 11, 2009
    5,939
    1,222
    Can you post a (good) picture of the switch circuit board :)
  9. iONic
    Nov 16, 2007
    1,422
    68
    I'd say $25.00 is a steal! I'll give ya $5.00 for it!!!!
