Device recomendation
Discussion in 'The Projects Forum' started by cheypr, Apr 12, 2013.
  1. cheypr
    Thread Starter Active Member
    Oct 13, 2009
    34
    I'm working on a security system but I'm not sure about what device to use. The system should work this way. I have a control unit at a place and a person with a tag. If the person walks out of range from the control unit at an approximate distance of 15 feet the alarm should be triggered.
    I was thinking to use an RFID with a microcontroller butIm not sure about the circular range and the distance. I was reading about an 915 MHz RFID to deal with the distance.
    I need some advice here. Thanks 4 your replies :cool:.
  2. MrChips
    Oct 2, 2009
    12,648
    3,458
    RFID wouldn't work. You need Bluetooth.
    cheypr likes this.
  3. cheypr
    Oct 13, 2009
    34
    OK, so with a bluetooth I can trigger an alarm if the person walks out of range, but how does the bluetooth can do that? I need to understand it to know how to interface it to a microcontroller or micprocessor.
  4. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    There is discussion about a similar project in this thread. Maybe some help there.
    As MrChips said, it uses bluetooth.
    cheypr likes this.
  5. KMoffett
    Dec 19, 2007
    2,584
    234
    Google: child luggage proximity alarm
    Ken
    cheypr likes this.
  6. cheypr
    Oct 13, 2009
    34
    Can anyone explain this to me. what does the values 0xXXX or 0xXX mean?
  7. tshuck
    Oct 18, 2012
    3,531
    675
    If you don't understand how hexadecimal is typically represented, then this project is probably too advanced for you.
    I would say go with KMoffett's advice and get a product that is designed already...
  8. cheypr
    Oct 13, 2009
    34
    so basically it means the actual value or range of values for each of those parameters.
    for the connection_handle paramter should be a hex type value of 0xXXX in the range: 0x0000-0x0EFF
    but for RSSI_Read Command succeeded parameter its a specific value: 0x00
    Am I correct?
