Device Driver
Discussion in 'Homework Help' started by hitmen, Apr 2, 2009.
  1. hitmen
    Thread Starter Active Member
    Sep 21, 2008
    159
    The output of device A is able to drive the input of device B provided that all these conditions are met:
    VOL (max) of A is ≤ VIL (max) of B
    VOH (min) of A is ≥ VIH (min) of B
    IOH (max) of A is ≥ IIH (max) of B
    IOL (max) of A is ≥ IIL (max) of B
    Can anyone explain or provide me with a suitable link?
    I only do not understand the first condition
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    The first condition?
    Unless the maximum possible low output value of A is always less than the permissible low input range of B, then A's output cannot be guaranteed to always drive B's input to the valid low state.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    Perhaps I could have more correctly stated the relevant part of the sentence as :-
    "... always no greater than the permissible low input range ..."
    - so as to better match the "less than or equal to" condition.
    Finding the words is never easy! I'll keep trying.
  4. hitmen
    Sep 21, 2008
    159
    errr I prefer a digram. where does the current flow?
  5. Ron H
    Apr 14, 2005
    7,050
    657
    The first and second statements are valid even if no current flows. All four are general requirements for any voltage-mode logic system - TTL, CMOS, ECL.
