Developing Equations for Single-Rail Op Amps
Discussion in 'General Electronics Chat' started by nDever, Jun 27, 2014.
  1. nDever
    Thread Starter Active Member
    Jan 13, 2011
    154
    Hey Guys,
    I built an inverting amp with a LM324N (sorry, I forgot to make a scheme). I applied a +5v signal to V- and got back +5v at Vout. I'm guessing that you can't get a negative voltage with a positive supply? If this is the case, shouldn't I have gotten 0v? Do you have develop equations differently for single supply op amps as opposed to dual rail amps?
    If you were wondering about the circuit, I have Vcc connected to 5v; GND is 0v. Feedback resistor (Rf) is across V- and Vout. I have +5v connected through R to V- and V+ is connected to GND.
    Closed loop gain is 0.1.
  2. crutschow
    Mar 14, 2008
    13,472
    3,359
    Yes, an op amp can't generate a voltage different from its power supply.
    The equations are the same.
    And yes, the output should be at zero. What is the value of the resistors? Post your circuit diagram.
  3. nDever
    Jan 13, 2011
    154
    Don't know the next time I'll be able to get back. I've got limited internet access right now, but my input resistor was 10k and the feedback resistor was 1k.
  4. crutschow
    Mar 14, 2008
    13,472
    3,359
    So the output should be near zero. Double-check all the pin connections on the op amp. Sounds like one or more are wrong.
