Determining Wind Direction
Discussion in 'The Projects Forum' started by circuitrynewbie, Apr 3, 2016.
  1. circuitrynewbie
    Apr 3, 2016
    Hi! I'm new here and to electronics generally. I'd just like to ask if there is a way to determine the direction of the wind using circuits. Like, maybe you could set-up six thermistors in six faces of a cube and whichever thermistor cools down significantly is facing the origin of the wind? Is that possible? Or maybe there are other clever ways to do this? Hopefully, ones that are easy to comprehend for a newbie like me.
  2. GopherT
    Nov 23, 2012
    6,314
    4,034
    Put a compass chip on a wind sock. See which way it turns.
  3. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    Small vane connected to a 360° continuous rotating pot.
    Add small pic etc.
    Max.
  4. #12
    Nov 30, 2010
    16,703
    7,341
  5. SLK001
    Nov 29, 2011
    851
    243
    A digital encoder connected to a wind vane.
  6. blocco a spirale
    Jun 18, 2008
    1,461
    370
    There are also systems that use ultrasonics to determine wind direction and speed.
    Search "ultrasonic anemometer".
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,522
    If needing a non-moving part vane, there is also the Pitot tube type sensors.
    Max.
  8. bertz
    Member
    Nov 11, 2013
    239
    32
    Check out this site.
  9. GopherT
    Nov 23, 2012
    6,314
    4,034
    Ok, are all entries in? We will vote at 3pm.
  10. tcmtech
    Nov 4, 2013
    2,113
    1,751
    Look out a window or step outside.
  11. bertz
    Member
    Nov 11, 2013
    239
    32
    +1
  12. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    One or two of the hobby magazines have published ultrasonic wind direction sensors, I didn't bother reading those articles - but the info is out there somewhere.
    Differential temperature sensors may not be so reliable if there isn't much wind chill factor.
    GopherT likes this.
  13. GopherT
    Nov 23, 2012
    6,314
    4,034
    A motor rotating a paddle. The motor should have a, encoder so you know the position of the paddle. Measure the current drop as it rotates through 360 degrees. Wind direction is 90 degrees from wind direction as paddle pushes into the wind. Lowest current drop when paddle is blown with the direction of wind. Wind direction and speed should be possible (requires calibration).
    Any other Rube Goldberg-like solutions out there?
  14. ian field
    Oct 27, 2012
    4,447
    791
    If you live next to the coast, you can watch which way the sail boats are tacking.
  15. ErnieM
    Apr 24, 2011
    7,438
    1,626
    Using any web aware code interpreter like Visual Basic for Obfuscation or Jelly Beans to go out to the interwebs and get a weather report for your local area.
